Old 04-07-2010, 08:50 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Spark plugs are not bad because I just have to undo 2 v-band clamps.
Yes the motor is built, has been for about 8000 miles now. I was never able to keep a motor together at anything above 150whp. As far as dynos, Im not making claims it is just general knowledge that Dyno-packs read higher. Most popular dynos are dyno jets, ours is a dyno-dynamics.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-09-2010, 01:27 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
If you are referring to a dynapack ( not dynopack ), those usually read LOWER than most dynos. The dynojet reads higher than most. However, obviously, weather and how it is calibrated makes a difference too.
Old 04-09-2010, 07:04 PM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Thank you for the spelling correction, as far as what you posted it is incorrect. I will go ahead and hop on a dynapack when I get a chance, and post sheets from Dynodynamics also. My boss once took his WRX he had (217 on our dyno) to a local dynapack and it put down 240whp. When I had my Blitz supercharger back in the day, I only put down 116whp on our dyno... it put down 138whp on a dynapack at a car show.
Dyno numbers are not a good way to compare set-ups unless everyone is at the same dyno. Even the same type of dynos, some shops use a correction factor.
The best test is mph trap in the 1/4. That does not lie.
Ptuning.com
Yarisworld Decal -SHOW YOUR YW PRIDE!! Astroman Items for Sale by private party 235 08-21-2019 10:45 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
xa/xb Turbo manifold for Custom set up CASTREX Forced Induction Forum 1 01-21-2009 02:43 PM
