Old 04-08-2010, 02:20 PM   #1
1stToyota
1stToyota's Avatar
That's funny because some new ignition wire sets come with the dielectric grease already pre-applied in the boot. And almost all of them throw a pack of dielectric grease into the box. And I always thought it was designed to dissipate heat, not cause a build up of heat. A little applied to the insulator saves the knuckles, and maybe the wire, when it comes time for the next tune-up.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-08-2010, 02:43 PM   #2
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
ok it depends on the type of grease. there are a hundred types.
some dielectric grease makes better contact or allows closer mating of metal to metal. in a plug boot, with some types of grease, there will be a bit less contact, and if the voltage has to squeeze through less contact surface area, it could heat up more than normal. it can also cause small arcs and burns if the voltage is great and the contact small. that is what I meant.
127.0.0.1 is offline   Reply With Quote
Where can I get iridium spark plugs??? fidgell Canada 4 03-01-2010 12:10 AM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
