Old 04-08-2010, 06:24 PM   #1
Emerge
On a trek to upgrade...
Drives: 2003 Echo Coupe
Headlight Restoration
Hello, I questions about headlight restoration. I have done the diligent work of reading through the forums, but I cannot find the appropriate answer.
I was at autozone and I saw two options:
  1. Meguiars Headlight Restoration Kit - 24.99
  2. Rain X Headlight Restoration Kit - 15.99
Which one is superior?
Are these prices decent, or could I find a better price elsewhere?
Are there any other options I should consider?
Emerge is offline   Reply With Quote
Old 04-08-2010, 06:28 PM   #2
yarrr
Drives: 07 sedan
haven't tried rain-x on headlights, but their other products are good.
The meguiars plast-x is good stuff. Works on headlights and the speedo plastic. The "restoration kit" is overpriced towels and crap with the plast-x. Just get a bottle of plast-x for under 10 bucks.
yarrr is offline   Reply With Quote
Old 04-08-2010, 07:08 PM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Are you familiar with wet sanding ? I believe that is what will be included in the kit. How bad are your headlights ? Have you tried rubbing compound over them ? Or if you have a buffer setting it at around 1600 rpm's with some extra cut compound then some polishing compound.
Old 04-08-2010, 07:07 PM   #4
^ this is good advice. And, I've recently tried to restore plastic turn signal covers (1990 Toyota pickup), and I can only say, use a power tool. Doing it by hand took HOURS, a good polisher will make short work of the job.
Old 04-08-2010, 09:01 PM   #5
Emerge
If it helps, I'll post pictures. The Meiguars comes with a buffer that attaches to a normal drill to make it really easy on you. So, that may be good?
Old 04-09-2010, 01:12 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Pictures help, Do you have any products at home such as rubbing compound and some sort of polishing compound ? If so then all you need is some 2000 grit sandpaper. I should have taken pictures of a 2001 solara i restored the headlights on, they were pretty gone, but i just wetsanded with the 2000, then used some Regular Turtle wax paste Rubbing compound, Then used a layer of wax, they came out pretty darn good.
Old 04-09-2010, 02:21 PM   #7
Emerge
Naw bro, I have no products at home. I've never done anything to my car before and thus I have no tools etc. I'll get some pics right now.
Old 04-09-2010, 02:55 PM   #8
Emerge
Headlight Pictures
Here they are. I hope they suffice, I have no picture taking skills. :(
At any rate, if they do not suffice, you could always tell me how I should take the pictures and I'll just reupload.
Old 04-09-2010, 02:56 PM   #9
Emerge
I guess you have to click the thumbnails to see the full picture.
Old 04-09-2010, 11:50 PM   #10
_S7V7N_
_S7V7N_'s Avatar
They're actually not that bad, Since you don't have any type of stuff at home, the kit would probably be the cheapest route. Just read it before you buy it and see if you're comfortable doing the entire process. Like i said some will give you a 1500 grit sandpaper and a 2000 grit sandpaper. You will then wetsand the headlights. The 1500 will be to knock off all the oxidation from the headlight, then the 2000 will be to smooth out the scratches from the 1500. After that it'll have some sort of compound to buff out the scratches from the sanding. Then after that it'll more than likely have some sort of sealant, Or basically...Wax.
I'd try to find some sort of tutorial on whatever product you buy, do an online search and try youtube, You'd be suprised.
Old 04-10-2010, 12:52 AM   #11
Emerge
Thanks I'll do just that.
Old 04-10-2010, 03:38 AM   #12
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i heard you can use tooth paste....
Old 04-10-2010, 08:18 AM   #13
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
^+1 dude if it works for cds it should work for headlights lol
zachryboles is offline   Reply With Quote
Old 04-10-2010, 03:43 PM   #14
Emerge
Seriously? Lol
Old 05-19-2010, 01:44 AM   #15
Nihow
Drives: Toyota
Great product, comes with 3 pads (basically sandpaper), a lubricant for wet sanding, a plastic polish, and a sealer for a good price. Took my headlights from zero to hero in only a few minutes! I was surprised how great these worked. They're not absolutely perfect now, but considering how trashed my lenses were... I'm happy.
Nihow is offline   Reply With Quote
Old 05-19-2010, 06:10 AM   #16
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
how much is new head light covers, just get new covers it will save u alot of time and it will up lift the car again,
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 05-19-2010, 10:15 AM   #17
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
If your headlamps have already turned yellowish/hazy I've used the Meguiars plastic cleaner and polish with good results. If you're in the early stages of hazing I use Plexius available at most motorcycle shops and other than pits from sand/small stones my headlamps look new. Plexius makes the taillamps look shiny like glass and you can make an instrument lens look new.
UTVitz is offline   Reply With Quote
Old 05-21-2010, 04:31 PM   #18
Emerge
So, I tried the Rain X kit.
It did work, but not as well as I expected. It looks much better than my other headlight, but far from "new" or even "newish" type of look promised. Could it have been that I didn't put enough elbow grease while sanding the headlights?
I can post pics if you guys would like.
headlight, headlight restoration, headlights
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Headlight fog elsteverino889 Cosmetic Modifications (Exterior/Interior) 2 03-28-2007 06:38 AM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 01:35 PM
