![]() Drives: 09 sedan Join Date: Mar 2010
We are talking about the connector furthest left of that picture, right? I ordered two spiral connector repair terminals and one ecm repair terminal. The connector in the ecm repair terminal looked like a perfect fit for the ones in the steering column. Should I go for two more of those or do I have the wrong connector?
#2 | |
http://www.yarisworld.com/forums/sho...ght=diy+cruise |
![]() Drives: Yaris 2007 hatchback 5 doors Join Date: Nov 2010
Reusing the chutch switch to turn off the cruise
Guys,
I had I idea, and i need your opinion before trying it. The yellow wire on the clutch switch that blocks the start (i am talking about the one on the bottom, not the additional we should add to stop the cruise), has normally (when released) 12V, high impedance (my guess is a pull up resistor inside the ECU). when pressed (the clutch needs to go to the bottom), that line goes near 0V (pulled down by the starter relay coil). What if we sense that in order to stop the cruise? For example, a mosfet transistor will do the job perfectly. The problem: the cruise will disable ONLY if the clutch is COMPLETELY pressed. What will happen during the clutch travel? Cheers! |
#4 | |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
