Old 04-10-2010, 10:16 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
So do I, and I've never had any questions asked about it. As long as they aren't MASSIVE 1000+ Watt amps each.
If you have the tunes pumping as you drive with the fan going, the lights on, it's totally normal for the voltage to fluctuate. That why you normally need a big capacitor hooked in parallel with the amp wiring. It reduces voltage fluctuation.
Old 04-11-2010, 10:48 AM   #2
MGargano
Drives: 2009 Yaris Hatchback
I just have a feeling they'll blame the amps and HIDs, whether they're what's really causing the problem or not. Maybe I can disconnect them and hide the wires, so they can't take the easy way out and use them as the cause.
I'm seeing the fluctuations with and without the load, which is what's bugging me. If it was only happening with everything turned on, I wouldn't be concerned at all.
I would definitely look into this if the fluctuation was only happening with the amps on. It's frustrating that it's happening all the time.
MGargano is offline   Reply With Quote
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 10:23 PM
FS: Blue Pulley Set Shijima Items for Sale by private party 12 09-18-2009 08:34 PM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
Feeler: NST 10% Underdrive Crank Pulley - Gray Black Yaris Items for Sale by private party 10 04-29-2009 11:24 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
