Old 01-06-2007, 01:42 PM   #1
acrbill
Drives: Polar White Hatch
Originally Posted by DTM_Yaris View Post
The maf sensor is able to output over 8 volts. Thats not the problem. The problem is the voltage the ecu sees!
If it sees over 2.8 volts at "x" rpm and throttle position it will go crazy. Trust me I have done it.
But I am working around this, meaning the stock ecu will never know that it is force fed.
If the MAF sensor is on the inlet side of the turbo Its not going to have compressed air going through it so the reading of the air going into the turbo will be accurate when your not in boost. Maybe once your in boost the turbo is sucking in more air there might be an issue, but all you would need would be a voltage clamp. Thats strange that it reads 8 volts. I would have assumed that it was 5v like a MAP sensor.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 01-06-2007, 03:57 PM   #2
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
Whether the MAF is on the inducer or discharge side of the equation makes little difference for drivability. Closed loop operation was and is fine. My posts have been strictly about boost and open loop mode. The voltage clamp will not help when you are in boost either. The computer takes into account Airtemp, throttle position (or anticipated position for DBW), coolant temp, rpm and crank position.
It is not like the old days when we could just play the analog game. It has checks and balances in the algorithms.
It is very difficult to overcome.
DTM_Yaris is offline   Reply With Quote
Fiberglass enclosure / Stereo system bugnuts In Car Entertainment + Electronics (audio / video / alarm) 30 05-20-2007 12:11 PM
Immobilize and security system. Meow In Car Entertainment + Electronics (audio / video / alarm) 19 04-18-2007 05:40 PM
My Sound System mhero In Car Entertainment + Electronics (audio / video / alarm) 0 09-18-2006 11:50 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
Question about Toyota's shipping system Goose New YARIS Purchase Forum 4 04-30-2006 11:03 AM
