Old 04-15-2010, 04:31 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
keep in mind that the size of a magnet does not matter on how good a speaker is. Common misconception. Furthermore, it doesn't even tell you the strength of the motor... the way that the voice coil is wound and the height of the top & bottom plates have more of an effect on the motor's strength than the size of the magnet.
Old 04-15-2010, 04:39 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Some thing funny happened to me...
I had in my Tacoma a pair of (Pioneer) Premier 6.5 component speakers (not cheap) and guess what? I end up putting back the OEM speakers because they sound much better than the premier, although the OEM speakers from the Tacoma are much better quality than the ones I found in my Yaris.
I didn't know that the Zeus came with a blue LED inside! I'm going to have to play with that!
D.
CLA 250, 4MATIC
Old 04-15-2010, 05:23 PM   #3
derickveliz2
At Lunch I went for the right front seat, I was really scared about taking it off, I read in another thread people having problems but it was a piece of cake! took me no more than 10 minutes!
BTW, mean while I was over there I took the glove compartment off just to realize that there was no CABIN AIR FILTER, I did a small search here in YarisWold and found out that it's common. But I got so mad I wrote down an email to the dealer! and I got a stupid answer and at the end I got my self a free Cabin Air Filter. here are the emails...
__________________________________________________ ____________
I can't believe I got a new Toyota from you, and I just found out it came without a cabin air filter, that is a shame.
Thank you,
Derick Veliz
__________________________________________________ _____________
Hi this is Bill from Boch Toyota
I called Toyota to try and get an answer for you about the cabin air filter On the Toyota Yaris.
The only thing they could tell me is that due to the small volume of interior space the cabin filter does not work the same as in bigger interior cars, so Toyota decided not to install them, but if the customer really wants one we can try and fit the corolla cabin filter and tray. The part sells for around $27.00 plus tax
Plus the installation. I hope this answers you’re question.
__________________________________________________ ____________________
That is not a Toyota answer, please. I also have a corolla and a tacoma and let me tell you that the interior space of my corolla is almost the same as the Yaris.
the manual states you shouldn't operate the a/c without it
p/n 87139-YZZ08
Thank you,
Derick Veliz
Hi this is Bill from Boch Toyota parts again as previously stated I was passing the information Toyota gave me to you.
But I can say that if you feel you really want the cabin filter installed you are more than welcome to bring in you’re yaris and we will try and see if any of the other filters fit at no charge to you for the first filter and installation
I know this has been discussed before but just wanted to share with you.
Thanks
D.
CLA 250, 4MATIC
Old 04-15-2010, 05:41 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
D.
I would guess the pioneers have a metalic tweet (and lack a good crossover), which may sound a bit harsh, along with a much higher BL on the mid which might (depending on the other T/S specs) lead the an early/fast roll off on the frequency response (for midbass) compared to the oem units. The OEM units are designed to have somewhat weak motor (Bl) and a very slow roll off. They also usually lack a dedicated tweet which gives a much more laid back and anemic sound which isn't desirable, but at least it doesn't make you cringe everytime you hear a cymbal crash.
yeah, you don't get an air filter unless you ask for one... and really... its actually easy enough that i'd tell everybody to replace it themself. I've made my own using giant 3M Filtrete Home Filters, 25,000 miles later and still no problems. You get multiple filters for around $15 that way... if you buy the filters designed for it I believe you pay around $10 a pop at least, and thats for a non-toyota brand.
I actually have been thinking about changing my filter for the past week. I'll probably do it the same day I change my oil filter (doing 10k oil intervals now, with 5k oil filter intervals)
Old 04-15-2010, 05:57 PM   #5
derickveliz2
The Premier tweeters sound great! not so bad passive crossover, it was the 6.5 drive that was not handling the mid-low frequencies.
Thanks, I learn so much every day even if I only understand half of it! .
CLA 250, 4MATIC
Old 04-15-2010, 07:32 PM   #6
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
Don't take this the wrong way, but 10k oil interval is STUPID.
I don't care if you run a full synthetic.
I've been a mechanic for 25 years.
I've seen engines destroyed because people let their oil go LESS than 10k.
3-4k TOPS. New filter every oil change.
I change my Yaris oil at 3k intervals. I use Castrol GTX oil.
Oil is cheap, your motor is NOT.
Oil breaks down, and it is a suspension for the by-products of combustion.
I seen factory maintenance literature that says oil changes at 5-6k.
Spark plugs at 100k.
Yeah.... they can stick that up their asses.
Old 04-15-2010, 08:46 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
got tired of throwing away (recycling) oil that came out the same exact color as when it was poured in. The oil I get is far greater quality than what is needed for 5k. I hear what you say, and have made up my mind, no more is needed to be mentioned about it in this thread... There's no point in debating something that only time... errr... thousands of miles will be able to tell.
next week i'll let you tell me that running 44psi on the tires is stupid too.
Old 04-15-2010, 09:03 PM   #8
Alien Mantis
Secret Agent
Yeah, do whatever you wanna do, bro.
It's your engine.
44psi in the tires? Cool. I run 40-44psi in my Yaris tires.
I won't argue with that!
