Originally Posted by Black Yaris
how much did this cost you? and are these same pedals available for an Auto?
It was around $60 for the two pedal covers (clutch and brake) and the accelerator pedal. The IS250 pedal assembly was $60 from a local junkyard and the dead pedal I got off of flea-bay for $25.
The part numbers are 78101-20150 for the gas pedal (which requires a pedal assembly where the pedal is attached to the shaft via a pin) and for the manual transmission it's 31321-53010 for the brake and clutch, it's only for one, so you'll need to order two, one for each. For automatic transmission the part number is 47121-53010 I believe, but you may need to double check with a dealer to verify. No idea on the IS250 pedal assembly or the deadpedal part numbers though.
Originally Posted by YarisSedan
I just got the direct oem replacement just slips right over like a glove.
Yeah, I noticed those as well, but IMO they look way too cheap. Anywho this actually also changes how close the gas pedal is to the brake, so heel toe is easier.
