Old 04-15-2010, 09:22 PM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Originally Posted by STC View Post
Yes, you are correct... a mandate was passed for requirement in minimum amounts of Ethanol during the Bush watch. I know there is a push to up the amount to 20% blend. My question is... doesn’t a vehicle have to be re-fitted to run this concentration?
I expect a new Yaris will run on anything up to E25 without problems. I doubt they make special fuel systems just for the ones they export to Brazil. The company doesn't currently approve of using anything over E10 at present in the U.S. The EPA recently sponsored tests indicating that any cars built since 2000 ought to do fine with E20. Last year I read a fellow's post here, on the Toyota Nation or Clean MPG boards, I forget which, about his experiments blending E85 with E10 in his Yaris. It ran fine up to something over 40% ethanol, when it began to set lean mixture codes. I know many people have an almost religious fervor against ethanol in gasoline and believe it will cause terrible automotive disaster, but I've used E10 much of the time since 1977 in cars and motorcycles old and new, and never had any problems. It's more of an issue for outboard motors, 2-stroke powered lawn equipment, chainsaws and such using premixed oil.
Old 04-15-2010, 10:28 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
agreed, i remember about a year or two back reading about a somebody who took a newer car (not sure if it was a yaris)... and found that doing a 50/50 mix of E85 and E10 gave no problems.
Old 04-17-2010, 12:21 AM   #3
Yaris Hilton
Smile
Having mentioned Brazil, i went and took a look. They don't sell Yarises there. You can get a Corolla or a Camry, though.
Purchased a 2010 Yaris Sedan rye7jen New YARIS Purchase Forum 10 02-18-2010 06:09 AM
Got my friend into a 2010 Yaris Sedan! Thirty-Nine New YARIS Purchase Forum 8 11-12-2009 04:59 PM
