Old 04-18-2010, 02:34 PM   #1
jthebeh
Drives: 2007 Nautical Blue Yaris Sedan
To anyone that did what I did and pushed the rubber stopper down instead of up. I used a very small drill bit and twisted it with my fingers and it cought and I was able to pull it out. it took me about an hour to get this out, sucked big time
jthebeh is offline   Reply With Quote
Old 04-18-2010, 06:14 PM   #2
Henry G.
Drives: 2008 Yaris HB
OK, I DID IT!! When I first felt the car accelerate to hold the speed it made it all worth it.
Total cost $50, had to buy multi pack of resistors and second set of switches, still worth every penny.
Second switch pad ready for install
Plugged in ready for test drive. I used connectors to unplug the first switch pad and plug in the second correctly wired one.
Clutch jumper going to fuse box.
ECM wire tucked into harness
ECM and clutch wires coming thru heater hose grommet. Im not thrilled with this set up, I will likely get a grommet and drill a hole thru the firewall next to the hoses in the near future.
Ground wire going to bolt on gas pedal. I couldnt find the previously mentioned ground wire, this worked great, easy to get to. With the plastic re-installed you cannot see this wire at all.
AND final install.
Thanks for everyone who contributed posts along the way, the DIY and CTScotts expert info, after reading everything it all came together, I made it harder than it had to be by not getting the right resistors up front, and wiring in the wrong ones in the first switch pad. I have some extra resistors if anyone wants them PM me.
Hank
Henry G. is offline   Reply With Quote
Old 04-18-2010, 10:20 PM   #3
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
You should have been able to just push it out from the other end with a paperclip. I pushed the wrong way, too.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
