Old 04-18-2010, 08:24 PM   #1
Yariz
Drives: Yaris 3dr Hatchback
what about 1zz Injector with 1zz TB would you need a better fuel pump? Would it throw CEL? I have seen that people have done it but haven't heard if its worth the hassle.
Yariz is offline   Reply With Quote
Old 04-18-2010, 09:02 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You'd only need more fuel if you can get more air in.
The current problem with putting on a Corolla TB on the 1NZ intake manifold is the opening on the manifold is only as big as the stock TB. So IMO, it's a total waste unless you bore out the manifold to match the larger TB. It's like putting a restrictor plate the size of the stock TB without it being matched.
it's wider than the 1nzfe motor, so the end ports would pass the motor block. I was covering up those sections with JB weld but never got around to installing it since my 1zz throttle body had broken sensors and wasn't working. Till I find some money for another throttle body, it remains stored away for a rainy day.
http://yarisworld.com/forums/blog.php?b=108
I forgot you did this a while ago, right? I think you posted it up on Echodrivers.com. I think with a new intake flange you could make it work right.
Old 04-18-2010, 09:10 PM   #3
Yariz
Question
Well it was cheap, I can tell a difference, and it was super easy to install. Has anyone bored out the manifold that you know of?
Old 04-18-2010, 10:43 PM   #4
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
a flange probably would work better, but i don't have the resources to make one for cheap
taKuto is offline   Reply With Quote
1zz Throttle Body - what needs to be done to it kac Performance Modifications 25 11-20-2018 06:13 PM
1zz swap...is it worth it??? jouna Performance Modifications 12 11-10-2009 09:33 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
