Old 04-20-2010, 10:42 AM   #1
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Can you put a grounding kit on the small Braille batteries?
goliath1812 is offline   Reply With Quote
Old 04-20-2010, 01:25 PM   #2
severous01
you can put a ground kit on any battery. all you're doing is upgrading from a 10g battery cable to anything bigger....or even more grounds. now, i wouldnt go drilling holes every square inch in the firewall with grounds, but to be honest, the OEM grounding situation is not enough. you got one cable from bat to the strut tower, one from bat to engine, and a ground strap from teh block to the firewall.
i'd have at least gone with 8g from the factory, but then again, i got free 4g or whatever size it was (it was metric cuz it's from germany), and it was cheap enough for the ends...so i win both ways.
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
What's the difference in the Door lock Kits (wire and rod) mgthompson General Yaris / Vitz Discussion 5 03-19-2007 01:29 AM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
