Old 04-18-2010, 06:11 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
1ZZ-FE Manifold Swap
I know lots of you have swapped out you stock TB for the 1ZZ's, but has anyone tried to swap out the entire manifold?
I was going to take some pictures and measurements of one to see what the differences are.
I remember a while ago at Toyota we tried putting a TRD 1ZZ S/C on a 2ZZ for a show car, but the manifold on the 1ZZ was narrower than the 2ZZ and would fit. Therefore, I'm wondering how close it is to the 1NZ.
The older NON VVT-i 1ZZ-FE has an aluminum tube style intake that would be nice on the 1NZ. Not to mention the addition of the bigger TB.
Thoughts?
Old 04-18-2010, 08:33 PM   #2
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
it's wider than the 1nzfe motor, so the end ports would pass the motor block. I was covering up those sections with JB weld but never got around to installing it since my 1zz throttle body had broken sensors and wasn't working. Till I find some money for another throttle body, it remains stored away for a rainy day.
http://yarisworld.com/forums/blog.php?b=108
taKuto is offline   Reply With Quote
Old 04-18-2010, 09:24 PM   #3
Yariz
Drives: Yaris 3dr Hatchback
what about 1zz Injector with 1zz TB would you need a better fuel pump? Would it throw CEL? I have seen that people have done it but haven't heard if its worth the hassle.
Yariz is offline   Reply With Quote
Old 04-18-2010, 10:02 PM   #4
Bluevitz-rs
You'd only need more fuel if you can get more air in.
The current problem with putting on a Corolla TB on the 1NZ intake manifold is the opening on the manifold is only as big as the stock TB. So IMO, it's a total waste unless you bore out the manifold to match the larger TB. It's like putting a restrictor plate the size of the stock TB without it being matched.
I forgot you did this a while ago, right? I think you posted it up on Echodrivers.com. I think with a new intake flange you could make it work right.
Old 04-18-2010, 10:10 PM   #5
Yariz
Question
Well it was cheap, I can tell a difference, and it was super easy to install. Has anyone bored out the manifold that you know of?
Old 04-18-2010, 11:43 PM   #6
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
a flange probably would work better, but i don't have the resources to make one for cheap
Old 04-19-2010, 09:45 AM   #7
pretty sure the bolt pattern won't line up
toyotatech from TN said very specifically to me via PM that it wouldnt fit
Old 04-19-2010, 12:06 PM   #8
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Ask Tamago, if I can go home and find the convo me and him had about this I will post it up. Supposedly another intake manifold from an older celica or something can bolt up to a 1nz with small modifications. I dunno if the outcome was doable or what, I will have to check it out
On second thought it might have been the old corolla as reading per your blog because i remember him saying it was aluminum, but he had insight on how to make it work. But definately no JB Welding for sure, do you want to take the risk of that stuff going into the engine? Just take it to a welding shop, it will cost $20 - the $8 you paid for JBweld :). I could've just save you some moneys!
Old 04-19-2010, 11:58 PM   #9
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
good idea nexus, my friend I believe has a MIG welder, i'm not sure if that would weld onto aluminum. Maybe I should just find a thin piece of metal, dremel out the 1nz ports and bolt holes, and have that act as a blocking plate instead of the JB weld?
The manifold's holes were shaved to the point where it'll let the bolts go through, so yes it can be modified to fit. Never got around to installing the nuts to hold it in place, not sure if there's enough clearance for all the holes.
Old 04-20-2010, 02:03 AM   #10
kou
Drives: 08 lb
Did you gain any hp or lose some from the swap.
Old 04-20-2010, 06:16 PM   #11
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
Looking for something that's easy to work with, I thought about using a blank FR-4 board. I do some high frequency electrical prototyping so I have some boards laying around. This is easy to cut to shape since it's fiberglass/epoxy, and according to wiki it'll handle up to 140C/284F temp.
Would the motor block get hotter than this, and would there be anything else to worry about to change my mind in choosing this to make my blocking plate? I could just epoxy the edges of the holes I cut so that the dust wouldn't find its way into the motor.
Old 04-21-2010, 03:40 AM   #12
Nexus1155
Drives: Audi
You'd need to get it TIG welded, some MIGs can do TIG welding but I have never seen it done on a MIG before, it would be easier and cheaper to take it to some place and have them do that, but obviously it will hinder airflow, but i don't know by how much though.
Old 04-21-2010, 10:00 AM   #13
Bluevitz-rs
I've done Aluminum on my MIG. I needed to change my liner and you need to run pure argon gas not mixed argon/Co2 (though it still works, just not as well). Wire feed speeds go way up and amps go down to weld.
You should technically have a wire-feeding gun for smooth operation.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
1zz Throttle Body - what needs to be done to it kac Performance Modifications 25 11-20-2018 07:13 PM
1zz swap...is it worth it??? jouna Performance Modifications 12 11-10-2009 10:33 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 11:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
