Audio Junky
ok... .what brand of mat are you using then?
I'm using RAAMmat BXT from www.raamaudio.com
You can see the difference in the pictures with CLD Tiles, the tiles have no wrinkles... and I'm using RAAMmat BXT to block holes, and corners or on top of OEM material, some times to hold CCF in place and for plastic panels to add a little bit of strength. CLD Tiles from www.sounddeadenershowdown.com .
. CLA 250, 4MATIC |
For lunch I had a couple dozens of crunches and some kind of Yoga going on! getting the Firewall treated it's very hard, especially on your body. But not impossible!
I put a few peaces of MLV behind the Fan/Cabin-air-filter and hold it in place with foam an lots of pressure. You can see the green foam on the left, behind that I slided a layer of MLV. Then I took a big sheet of paper and kind of traced the corner shape all the way up, then cut a MLV following my traced paper and tuck in there, all the way up, the Amp wire is behind the MLV I don't know if this is ideal but it was kind of in the way; then hold it with a couple of bolts as you can see in the picture. I cut it longer than I need it, on purpose so the wheel well gets 2 layers of MLV, I don't know if helps, but in this area for me it was easier to overlap a lot, instead of gluing to seal the MLV. ![]() ![]() Thank you, D. .
. CLA 250, 4MATIC |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
Holy smokes! It took me 2 1/2 days to get through all the posts in here! I've learned alot and before I found this thread started to sound deaden my sedan. I'm using RAAMmat BXT II with Ensolite. So far I've done the entire trunk. I'm saving the Ensolite for the passenger compartment/doors. I've removed my rear seat and plastic pieces so I can get to the wheel wells. I've decided I want to get new speakers front and rear so with all the stuff currently removed from the back half it seems like the perfect time to replace the speakers. I plan on deadening the doors and floor, but that will be it. I'll keep an eye on this thread and on SQComp's build too regarding the headliner. Hmmmmm.
Anyway this is a most excellent thread! I'm not going anywhere near as Xtreme as you Derick, but I applaud your efforts! Keep up the good work.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
#5 | |
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
