Bathroom + Laptop = <3
RATTLE?!?!? From where?
Ok so this problem just started to happen and it is baffling my brain.
Just when cruising along I can hear a rattle, sort of like there is a screw or rock inside of the exhaust just getting jostled around. It is coming from the right rear of the car and it is really driving me nuts. Or atleast sounds like the right rear of the car. Anyone have any ideas?!!? |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
First check items in the cargo area, seat belts, center rear seat belt. This is often the case for me. My last rattle was a loose seat bolt, loose interior clips, cd covers, and a wire harness that vibrated.
#3 | |
Audio Junky
the trick is to know if it is a metal, or plastic rattle. I had an issue with my rear brake light indicator, but it could be anything... so i'm not even going to try and guess. |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
Check your spare tire area and the tool area on the right side of your spare tire to see if there is something there might hitting around while you are driving.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
If it's the rear brake light assy, you can stuff a towel up against it through the covers in the rear, without removing any panels.
my yaris has so many rattles, it pisses me off!
Thanks everyone I'll try to check some things out tomorrow
And I don't think I would mind a couple of rattles if I had a turbo/supercharger... |
I found that almost every interior clip in the dash was rattling, or at least loose enough to rattle when tapped. So put scotch tape inside every one of them, and silence the dash....
i had a rachet extension fall into my spare tire area and it took me about a week and completly ripping my car apart to find out that was the niose. lol. it really sounded like it was coming from under/outside the car.
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2010
I managed to drop an allen key inside the rear bumper of my sedan while putting the wires into my amp. Wasn't able to find it :P
| Rattle noise under the speaker’s cover - sedan | karat747 | DIY / Maintenance / Service | 1 | 10-22-2011 08:41 AM |
| DIY- rattle from lower windshield fix. | PetersRedYaris | DIY / Maintenance / Service | 3 | 08-21-2011 12:29 AM |
| rattle | bluebeast | General Yaris / Vitz Discussion | 1 | 04-12-2010 01:13 PM |
| Exhaust rattle? | Cutie Pie #2 | DIY / Maintenance / Service | 3 | 11-14-2008 06:46 PM |
| Rattle fixed! | Bretsuaz | DIY / Maintenance / Service | 32 | 03-30-2007 08:39 PM |
