Old 04-22-2010, 12:20 PM   #1
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Originally Posted by talnlnky View Post
the ohm load of the speakers should actually be about the last thing you should be worrying about. A 4ohm speaker is generally more efficient than a 2ohm speaker, so, the additional power that a 2ohm speaker usually doesn't make much of a difference.
I've ran 4ohm & 8ohm speakers before.... you won't here an audible difference between them... its all the other specs that will make an audible difference.
Thanks! I wasn't sure if the 2 vs 4 made a difference as far a power requirements from the HU as I know zip about the stocker in my car.
Lookin' good Derick! You're gonna turn into a walking zombie with all those late nights! I hear you about the family, especially with a youngster demanding your attention. So...when are you to to "mod" the play structure? Stereo? Fridge? Ceiling fan? Lounge?
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 04-22-2010, 03:34 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I just met my worst night mare!!!........FRONT RIGHT DOOR TRIM PANEL!!!
I can't believe it, it was so hard... I know the extra layers of CCF and MLV was too much and I knew I was going to trim them to make it fit; I put on and off that panel maybe a couple dozen times, maybe more!!!, I spent all my hour of lunch trying and trying... at the end I was successful. Also had to take away the little foam on the upper part, and cut all the way down the big one.
Looks like there are main points in the panel that go agains the inner door and felt like little bumps deflecting the panel making it impossible to put back in place.
I hope this helps me plan the drives side door better.
I'm exhausted
I was so lucky my boss came back from vacations and he brought 2 pizzas for us!
CLA 250, 4MATIC
Old 04-22-2010, 03:46 PM   #3
derickveliz2
I forgot to mention, that the THUMP coming from the door when I slam it...
it's so GOOD, it's PRICELESS
CLA 250, 4MATIC
Old 04-22-2010, 06:39 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
OHHHHH... crap.... I totally read your entire post... and somehow glazed over when you said STOCK DECK.... if you plan on running the speakers off the deck's internal amplifier, then I would stay away from the 2ohm speakers. I thought you were going to power the speakers off an external amplifier (i'm blond, don't crucify me).
the 2ohm load on a deck will cause it to run very hot, and possibly blow fuses. There are a lot of electronics that give off heat in a deck even before you consider the amplifier. I have a deck that doesn't even have an internal amp, it only has a 2amp fuse, and the front of it gets warm.... now compare that to a deck which will have around a 10amp fuse.
Usually when people talk about running a 2ohm speaker, it's because they want to get every last watt of power out of their external amplifiers.
Old 04-22-2010, 07:02 PM   #5
Herbicidal
Herbicidal's Avatar
No worries! I know just enough to believe the 2's were not the best choice for my stock HU. I bit the bullet and just ordered these 4ohm units from SonicElectronics:
1. Kicker KS60.2: 1 @ $109.99 (doors)
2. Alpine SPR-69C: 1 @ $99.99 (rear deck)
I've got my car 1/2 torn apart and would like to ONLY get into the doors and rear deck once!
Better to beg for forgiveness than ask for permission!
