![]() ![]() Drives: white stock yris Join Date: May 2009
It seem when the springs are loaded, the dampers dont damp enough. On a straight road (springs slightly loaded ) the shocks are fine. I have a 23 mm sway. Is ok to replace the rears shocks only?
#2 | |
They are designed as OEM replacement but do have increased rebound damping. I used a full set on my Talon with Eibach lowering springs and it rode well and handled nicely. They're inexpensive as well. The next step would be TRD or Tokico dampers. But both are valved considerably stiffer so puting them in the rear alone may be a serious mis-match with OEM front struts. Also, I'm not sure you can buy the TRD rears separately.
| NST Crank Pulley Reliability? | WeeYari | Performance Modifications | 59 | 02-10-2010 01:20 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Track Virgin No more. | nurburgring | General Yaris / Vitz Discussion | 18 | 06-12-2007 11:17 AM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
