Old 04-24-2010, 10:59 AM   #1
Yariz
Drives: Yaris 3dr Hatchback
Post
Originally Posted by Creamed Corn View Post
Hey whats up everyone? I'm new here, and no Yaris just yet, but I just had a few questions primarily regarding some performance parts for the Yaris. First off, i'm aware that the Yaris is based off of the same platform as the xA/xB which have a massive following/aftermarket. However, after doing some research, I noticed alot of parts, like the HKS Hi-Power exhaust for instance, are only listed for '07-'08 Yaris's (Yari?). I'm aware of the cosmetic differences, but are there any real mechanical differences between the '07-'08's & the '09-'10's? Or are all parts backwards compatible between the the two generations? Any and all help is greatly appreciated. Thanks!
Most simple things like the exhaust, and stuff will probably work as long as its 1NZ, make sure.. Also, you should read up on the particular part. This is NOT something ANYONE can give you a blanket answer for. Trust me. Plus most of what you will hear is opinion. So in short, start with 1 part, and find out. Then you can go to the next. Sorry its not a YES/NO answer.
Yariz is offline   Reply With Quote
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 08:55 AM
C-One performance parts for Yaris Sedan? trdyaris1 Performance Modifications 3 05-23-2007 02:07 AM
