Old 04-24-2010, 02:31 PM   #1
Originally Posted by beZzZ View Post
......but wondering which one to get, TRD or NF210? My tire spec is 175/14.......
Any suggestions from you guys?
In deciding between these two, one thing to consider is the actual drop of the springs.
TRD is an equal drop of ~1.25 inches front and rear.
NF210s do not drop equally front and rear. They spec at 1.1" front, 1.3" rear.
My preference is an equal drop all around, and therefor would not personally choose NFs. They are also quite a soft spring. I believe TRDs are a bit stiffer.
Old 04-25-2010, 09:44 PM   #2
beZzZ
Learning & Upgrading
beZzZ's Avatar
Drives: 2006 Yaris 5 Dr HB Black
Thanks for your info.......my concern is that for TRD that is more stiffer, will it be really bumpy when driving?
beZzZ is offline   Reply With Quote
Old 04-26-2010, 07:26 AM   #3
Nope, still quite comfortable. My Megans are way stiffer than TRD, and my ride still isn't that bad.
Old 04-26-2010, 12:28 PM   #4
beZzZ
beZzZ's Avatar
Ic, I might go for TRD at the end, thanks for the information
Tags
lowering, rims, springs, wheels
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
Factory Lowering Springs + MAX Wheels? What are the options? bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-24-2006 08:10 PM
