Old 04-26-2010, 01:40 AM   #1
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
K. I think I get it now. Is the s/c activation sw still operable there poop? H3 do you know?
Got boost?
etheliters is offline   Reply With Quote
Old 04-26-2010, 01:55 AM   #2
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Chino made "158 WHP and 148 TQ" @ 7 lbs w/emanage
I made "155WHP and 135 TQ @ 4 lbs on the factory ECU
That why Peter doesnt have confidence on the blue
Chinos wastegate is also fluttering causing him not to get as much power as he can be. Also he is running proper AFR while the factory ECU will lean you out to 14.7 every time.
You and chino are using the same turbo?
Old 04-26-2010, 02:08 AM   #3
H3LlIoN
Drives: '09 Yarrrr hatch
AFAIK, the s/c activation switch would still be operable. The piggyback systems get wired in to the factory harness, and are designed to edit/alter/adjust fuel and ignition curves.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
E Manage Ultimate cdydjded Performance Modifications 5 05-14-2009 01:37 PM
Elusive Greddy Ti-C? RShatchback Performance Modifications 36 06-05-2007 04:11 PM
