Old 04-27-2010, 04:59 PM   #1
nemelek
DWEED
nemelek's Avatar
No I don't. I would check your oil level and add more to put it on the full mark.
Old 04-27-2010, 07:00 PM   #2
dingbat
Drives: '10 3D Liftback
+1, Do it now!
dingbat is offline   Reply With Quote
Old 04-28-2010, 11:25 AM   #3
colinr5779
Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i
Topped it up 2day with 1ltr its hard to gettin a clear reading
colinr5779 is offline   Reply With Quote
Old 04-28-2010, 09:27 PM   #4
dingbat
Was it low to start with?
Hard to get a clear reading on the dip-stick? Let the car sit for a while. Pull the stick and wipe it clean. Stick it in, pull it out again. Should give you an accurate reading. If you've just poured in cool oil, it can sometimes take a bit for it to work its way down into the pan. Best to let it sit and re-check to make sure you didn't over fill it.
Did adding oil take care of your light issue?
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
