#1 | ||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
![]() Cheers! M2
Half a Bubble Off Plumb
Carrying a compressor is a good idea.
It's false that nitrogen is denser than air. It's a little less dense. Gases' densities are directly proportional to their molecular weights. Air (dry) is approximately 78% nitrogen, around 21% oxygen, with various trace gases making up the rest. Oxygen's molecular weight is about 32, nitrogen's 28, so air with its oxygen content is a little denser than nitrogen. I doubt you could measure a significant difference in the leakage rate. Nitrogen's a current "snake oil" fad for the most part. |
#3 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
That's why I said "for the most part." It's long been used in jet aircraft tires that get really hot, too. And avoiding the water that builds up in tires with compressed air is a good thing.
#5 | |
Drives: 07 sedan Join Date: Mar 2010
The idea behind nitrogen fills isn't about density, its about the size of the molecule, and a nitrogen molecule is bigger than an oxygen molecule. This supposedly helps individual molecules from seeping through the rubber. |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
My compressor doesn't use the car's battery. It has it's own power supply. You just have to charge it up once every 6 months, which is that big of a problem.
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
