Old 04-28-2010, 02:34 PM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Carrying a compressor is a good idea.
It's false that nitrogen is denser than air. It's a little less dense. Gases' densities are directly proportional to their molecular weights. Air (dry) is approximately 78% nitrogen, around 21% oxygen, with various trace gases making up the rest. Oxygen's molecular weight is about 32, nitrogen's 28, so air with its oxygen content is a little denser than nitrogen. I doubt you could measure a significant difference in the leakage rate. Nitrogen's a current "snake oil" fad for the most part.
Old 04-28-2010, 03:07 PM   #2
127.0.0.1
nitrogen is not snake oil for the racetrack where tire temps hit extremes. but everywhere else, yes snake oil
Old 04-28-2010, 04:43 PM   #3
Yaris Hilton
Smile
That's why I said "for the most part." It's long been used in jet aircraft tires that get really hot, too. And avoiding the water that builds up in tires with compressed air is a good thing.
Old 04-29-2010, 02:48 PM   #4
yarrr
Drives: 07 sedan
For the record, I run good ole regular air in my tires, but:
The idea behind nitrogen fills isn't about density, its about the size of the molecule, and a nitrogen molecule is bigger than an oxygen molecule. This supposedly helps individual molecules from seeping through the rubber.
yarrr is offline   Reply With Quote
