![]() Drives: 07 Yaris Hatchback Join Date: Jan 2007
My first post here.
I have the Tanabe NF and have installed the rear springs. I have not installed the front because I can't locate a manual on how to access the top of the front shock assembly. Any help/info out here on how to/DIY? Thanks.
2007 White Liftback 5-speed Tanabe DF 2" lowering springs, 205/50-15 on 15x6.5 Konig Helium, TRD rear sway bar, 15mm Hub spacer http://picasaweb.google.com/USAntonio/MyGarage# |
#2 | |
http://www.yarisworld.com/forums/sho...67&postcount=1 Im in Jersey too btw.
I love my new NF210's. Installation was not bad at all. For the front, I removed the wipers, plastic cowel, wiper motor assembly (only two 10mm bolts), then the whole metal assembly under the cowel. It looks like a lot of bolts to remove but trust me, it's really not bad. The whole thing comes right out very easily and goes back together easily with only one person. With all that out of there the engine compartment is very open and easy to work in and the strut towers are wide open.
Thanks folks for the DIY info on replacing the front springs.
BTW, here's some pics of the Tanabe springs. Real Japanese manufactured
coulda did them for you.. how do you like them?
What exactly do you have then? Your signature says DF, your box says NF. |
| TRD OR Eibach...i'm confused... | hoahmaru | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 39 | 11-07-2008 08:25 PM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
| TRD Lowering Springs | DJ_Trizzak | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 07-06-2006 11:20 AM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
