#181 |
#182 |
Diesel Inside
Drives: Yaris 1.4 D-4D Join Date: Feb 2010
can the removed module be installed on headlights with no DRL?
#183 |
#184 |
![]() ![]() Drives: 2010 3dr hatchback auto red Join Date: Jun 2010
No DRL ?? Good??
I picked up my 2010 3 door HB last week, 6 months old w 4600 miles and found this wonderful site. Lots of helpful info. I've been thinking about several DIY mods: removing the DRL & maybe the back Toyota name. But , Saturday I checked and I have no DRL. DO you think the first owner did the disabling? As I don't want it anyway I'm probably not going to do anything.
The car came with most packages & options, but I was disappointed yesterday to discover it does not have adjustable intermittent wipers, only fixed one speed. That should be standard. Is it something that could be added? |
#185 | |
For the true intermittent wiper piece, check out this thread for a DIY on replacing the stalk, with a Prius one. http://www.yarisworld.com/forums/sho...ight=diy+wiper |
#186 |
Wow, thanks for the info. I'm happy about the no DRL. The manual says how it works 'if equipped'.
The wiper mod looks simple. But, I'm having trouble finding a low price like you got. Will call some junk yards maybe. The online dealer price was about $148. |
#187 |
#188 |
#189 |
![]() Drives: 2006 3dr Yaris RS Join Date: Mar 2007
Disconnected DRL, is there a way to make the stock fogs work now?
#190 |
ur gonna have to put the module back in and only cut the big blue wire.
i personally opened mine up and cut a chunk out of the internal wires
#191 |
toyota
dont cut the wire..just pull it out just need small flat screw driver..
#192 | |
lol, y was i never told this?always trust the pull out method
#193 |
toyota
yah you can i was about to cut it then notice the drl box just slides out and just by looking at the blue wire you can insert a small flat screw driver on the side and itll slide right off..
#194 | |
Once I tried; i pinned out wrong cable :( It didn't worked. Then I didn't have enough time to try it. New marriage, new house, moving, holidays and lots of works. I will try in the following days and give my reply. Thanks for your helps. |
#195 |
I finally disabled on my 2010 canadian model.
I cut the green wire coming from the alternator and another gray wire coming from the alternator. I'll take photos tomorrow about which cables i cut. |
#196 |
finally,
here is the schema. |
#197 |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
I've had my Yaris only 2 weeks now, and am so happy to get the info on how to disconnect the damn DRL's! Just last evening, upon arrival home from a 25 mile freeway drive, as I pulled into my garage I realized I had been driving on the DRL's, and of course no tail lights. Hey I know it is a supposed saftey issue but in my case not so much!
My Toyota service manager I called was only good for telling me there was NO way to disable them, HA! |
#198 |
![]() ![]() Drives: 2zz MR-2 Spyder Join Date: Nov 2010
Thanks for this post-I owe you a beer.
I didn't read every page...but I truly feel the DRL setup in this car is dangerous! The DRL's are bright enough to lead the way at night, which allows you to drive off without your tail lights on at night, especially because the speedo lighting looks fine w/o the headlights turned on.
cheers! |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
