Old 01-08-2007, 09:56 PM   #1
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
Originally Posted by mutatio View Post
for non crazy drivers the rule of thumb is essentially that if u can get the stick into gear in the first place without forcing it, you're in a good place. anytime u feel it grind when u r trying to move it into gear means you're forcing it. as noted u may need to boost your rpms for it to slide in. but no, a double downshift isn't an insane thing to do, assuming you're being responsive to the tranny's feedback. i typically downshift from 4th to second around corners that i'm approaching at a decent clip. 3rd will do, but 2nd gives u the pull coming out of the turn and there's usuallly never any forcing of the gears. your tranny will let u know when it doesn't like what u r doing! ;) :)
No im not taliking about u taking a turn that u will brake first then switch to 2nd, im talking about non braking, double downshifting to gian extra speed when going straight. ANd what do u mean by forcing the gears??? i have never felt that before, the only thing i felt is that i can never shift the stick in to 1st whenever im over 10MPH and when u try to shift form 5th to R. the shifter wont let the stick to shift in ,in those two cases, but never felt that i have to force the stick in to any gears, im not getting what you are trying to tell me sry
Yaris TTE JWRC is offline   Reply With Quote
Old 01-08-2007, 11:05 PM   #2
Pars
Drives: 07 Yaris Liftback
If you're not using heal-toe to rev-match when downshifting, the actual process of downshifting for both speeding up or slowing down are executed in same manner. Once the shifting is completed, then you can speed up or slow down, but that's after the downshifting has been executed.
If you're not understanding (or it seems too simplistic), then I'd stay with the basic for awhile and just try to be smooth and keep the clutch burn to a minimum (meaning, avoid having the clutch partially engaged and accelerating while on the move). If you can do that and shift as smoothly as an automatic transmission, then the fancy stuff will be a piece of cake.
Usually when a driver is referring to forcing the clutch, it means not giving the synchronizers enough time to equalize the engine speeds (which will put extra wear and tear on the syncs). To give the synchronizer time to do their job, it's better to shift slowly, but not slow enough to be jerky with the car (everything still should be smooth). In my case, when I'm on the boil, which is most of the time, I'm switching as fast as my hands can move. But it's a trade-off, and manual transmission are usually designed to be abused. But there so much they can take and if you're in-experience and forcing things (in general), you're going to quickly wear-out your transmission. Mis-shifting is the kind of stuff that'll cause all the nasty noises from the tranny and the only thing that can be done it that situation, is to go back down on the clutch as fast possible.
Pars is offline   Reply With Quote
Old 01-10-2007, 01:09 PM   #3
mutatio
Drives: Flint Mica AT Sedan
the following basically covers it. :)
Originally Posted by 07WYarisRS
If engine or car speeds are too high for that gear it's going to grind or over rev the engine and cause damage.
mutatio is offline   Reply With Quote
Questions on pricing littlecarlove New YARIS Purchase Forum 17 10-29-2006 07:53 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
More questions Buckethead DIY / Maintenance / Service 1 08-01-2006 12:46 AM
Newbie questions about the 2007 Yaris urabus General Yaris / Vitz Discussion 11 07-06-2006 11:32 AM
new owner.. have questions chibianh General Yaris / Vitz Discussion 8 05-14-2006 11:44 AM
