Old 04-29-2010, 10:54 AM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
A 4-cylinder engine is balanced to run as a 4-cylinder engine. If you disable one cylinder, the remaining three will not run smoothly. You could DO it, but there's no way you could sell such a car because on 3 cylinders, it wouldn't idle smoothly and it wouldn't run smoothly.
In reality, it would probably take MORE fuel to run a 4-cylinder car on 3 cylinders due to that inherent imbalance which would need to be overcome.
Cutting cylinders works in something like a V8 engine (I think I read that the new Chryslers like the Charger are doing it for economy, so it's not just the historic Cadillac failure) where two or four cylinders can be dropped and still retain a somewhat balanced cycle.
Old 04-29-2010, 11:15 AM   #2
H3LlIoN
Drives: '09 Yarrrr hatch
Yeah, Chrysler, Honda and GM all have some type of this tech in effect and available on new cars.
OP...I was thinking about this last night...for some reason, I seem to recall that it only works on a V style engine. Smallest I can find is V-6.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
