#19 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
#20 |
Half a Bubble Off Plumb
That's why I said "for the most part." It's long been used in jet aircraft tires that get really hot, too. And avoiding the water that builds up in tires with compressed air is a good thing.
#21 |
My compressor doesn't use the car's battery. It has it's own power supply. You just have to charge it up once every 6 months, which is that big of a problem.
#22 | |
Drives: 07 sedan Join Date: Mar 2010
The idea behind nitrogen fills isn't about density, its about the size of the molecule, and a nitrogen molecule is bigger than an oxygen molecule. This supposedly helps individual molecules from seeping through the rubber. |
#23 |
#24 | |
#25 |
The oxygen molecule is about 3% smaller than the nitrogen molecule. Works in membrane diffusion oxygen concentrators, but I remain skeptical that you can measure a difference in leakdown rate in a tire. Snake oil.
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
