Old 05-06-2010, 11:51 AM   #1
Kongo-Otto
Drives: '09 Yaris & '10 Auris
This cant fit because the 1NR-FE has the exhaust header at the front and the intake manifold in the back. Something new has to be developed for this engine.
Old 05-07-2010, 04:19 AM   #2
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
yep, you're right but it was just an example... I was thinking that was possible to adapt some other "simple" intake, but perhaps it's too complex
anyway I studied the situation again and I was thinking also to leave untouched the original airbox, just (as I did) replace the OEM filter with the K&N (33-2211 model) and removing the original arm...
as you know the original arm seems too thin & above all it doesn't turn close to the floor, so it sucks (almost) warm air
the idea was to remove the OEM arm & installing something like RamII (80mm section) downturing it close to the floor near the right fog lamp
do you have some other ideas??
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 05-07-2010, 05:01 AM   #3
Kongo-Otto
Its thin and surprisingly short but you dont have to remove it for intake air temperature issues because there are none. I measured the intake temperature with a Scangauge II. Its warm while you are not driving but as soon as you are moving it sucks cold air.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 04:24 PM
Anyone need ECU tuning done on American Vehicles? Nexus1155 New England 5 06-10-2009 07:15 PM
Save $20 on every TWM Performance short shifter/shift knob combo! TWM Performance TWM Performance 4 05-29-2009 04:36 PM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 08:46 PM
