Old 05-06-2010, 02:48 PM   #1
anexrx7
Drives: 08 MM HB
Front sway bars have two bushings, though.
Our rear axle is single beam, so it's not really a sway bar; it's a torsion bar.
I've been trying to figure out this for a while. I have a rear swaybar on the RX-7 but it attaches to the body underneath. Does this do the same thing on the yaris or does it just attach from one side to the other on the stuts?
anexrx7 is offline   Reply With Quote
Old 05-06-2010, 05:05 PM   #2
yarrr
Drives: 07 sedan
It attaches to the shock and the shock mount(2 bolts each side) underneath the car.
yarrr is offline   Reply With Quote
Old 05-06-2010, 05:45 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
As Cali hinted at above, the Yaris rear "swaybar" isn't a real swaybar. It behaves like a swaybar, but it is really just a torsion bar that reinforces the twist beam rear axle. Hence no frame mounting and no end links, etc.
Old 05-07-2010, 03:33 PM   #4
anexrx7
Drives: 08 MM HB
Wow, so it makes that much difference? That is crazy.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
