#235 |
Roadrunner Jr.
It seems that we're all doing cool little projects.
I'll put up a step by step tutorial to go along with that Youtube video. That should take any guess work out of the removal of the integrated piece and install of an aftermarket source.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#236 |
I may be able to use my Pioneer DEH 835R Head Unit!
YEAHHHH!!!
. CLA 250, 4MATIC |
#237 |
I forgot I also have a Premier (Pioneer) 6 disk magazine, I guess is not a big deal since MP3s are so popular. I'll install it and keep there my 6 favorite CD disks.
(o: .
. CLA 250, 4MATIC |
#238 |
Roadrunner Jr.
It's been a while since I've seen one of those. When was this deck manufacured?
#239 | |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
Hey, I like CD's too! I might even have six!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
#240 | |
Wow ![]() ![]() ![]() ![]() , it's amazing how time goes by, I got this deck for my Tacoma back in 1999-2000 that's 10 years ago! ![]() ![]() ![]() ![]() ![]() . ![]() .
. CLA 250, 4MATIC |
#241 |
Ok, I had a very hard time trying to install a 10mm spacer in the rear left corner, It's amazing how TOOLS make a big difference. Now I have to do the other side...
HOW does... this translates into sound deadening... Well the Wheel/Tire is spinning 10mm away from the Wheel well! I hope I'm getting more stuff from Rick (RaamMat) tomorrow or Tuesday, we'll see. D.
. CLA 250, 4MATIC Last edited by derickveliz2; 05-03-2010 at 01:04 PM. |
#242 |
. CLA 250, 4MATIC |
#243 |
I just ordered a Toyota Bezel part # 55405-52640 for $91, should have it tomorrow.
(o:
. CLA 250, 4MATIC |
#244 |
I just got the Ensolite IUO Peal and Stick, and took pictures next to the CCF that I've been using. ![]() ![]() ![]() The Ensolite is almost as thick as the 1/8" CCF the good thing is that works like a sticker, so will help me apply it in the back of the trim panels. OHH NO! so much work to do!
. CLA 250, 4MATIC |
#245 |
Great pics! Honestly I'm not sure I would want to work with anything thicker than the 1/8" vinyl nitrile or the Ensolite that I have been using. For me, I'm not going for that much sound deadening!
#246 |
Thanks.
The foam not only helps absorb some very high frequency noises that the first layer of substrate may not block. And when trim panels buzz or rattle, the use of foam will isolate them from whatever they are rattling against. .
. CLA 250, 4MATIC |
#247 |
Wow...!
I just finished with the other spacer in the rear right wheel. It's just 10mm away from the wheel well but every grain of sand counts! Tomorrow will get rid of snow tires and put the new O.Z. shoes (o: .
. CLA 250, 4MATIC Last edited by derickveliz2; 12-15-2010 at 11:12 PM. |
#248 |
boydstir
looks like you really getting into making these tin cans rattle a little less i cant get enough sound deadning its the best to thing to to be able to enjoy driving these cars and a little bit of music helps also :)
[/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
#249 |
boydstir
[/IMG]
#250 | |
I've seen your pictures before, very nice custom speakers in the doors and for the woofer too. Did you plug in the sound system or they did it for you too? D.
. CLA 250, 4MATIC |
#251 |
![]() The new wheels look good, but I'm having rubbing issues in the back, and I tried to remove the spacer but it's close to impossible, I'm going to try with a RING-TYPE COIL SPRING STABILIZER ![]() to see if I can lift and stiff the rear a little bit, I'm going to need it any way to take care of the extra weight of the subwoofer box and the deadening material added to the car. This will be a temporary fix until I get coilovers. ![]() I got to go back and do some more deadening.
. CLA 250, 4MATIC |
#252 |
On a trek to upgrade...
Drives: 2003 Echo Coupe Join Date: Mar 2010
Just seeing all the work you have done tires me!
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
