Old 05-08-2010, 01:34 AM   #1
Raysi
Drives: Yellow Yaris Sedan
How do I disable safeties on my yaris?
I want to disable safeties so I can race my friend- I want to clock it up to 200mph. Is there a secret button inside? should I mess with something under the hood?
Thanks!
Raysi is offline   Reply With Quote
Old 05-08-2010, 11:06 AM   #2
GrimlockGT
GrimlockGT's Avatar
Drives: 2009 3DR Blizzard Pearl CE
Only the LB model can reach 200mph and alas, you have the Sedan. There is a secret button, just not on your car.
GrimlockGT is offline   Reply With Quote
Old 05-08-2010, 11:11 AM   #3
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
correct. you need to pull the steering column and cut one wire and cross 2 others.
kind of a pain, but worth the effort. gas mileage drops a bit though
127.0.0.1 is offline   Reply With Quote
Old 05-08-2010, 01:26 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
only SLIGHTLY..... TOO BAD he bought the weaker of the 2.
Old 05-08-2010, 01:35 PM   #5
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
well your dealer should know. Take it to him and have him set it up. Then post what he says so you can help us all out.
Yoda is offline   Reply With Quote
Old 05-08-2010, 03:47 PM   #6
ddongbap
Nah! Ya'll nuts dude. You gotta put some blinker fluid in the rear radiator, to activate the tail light bearings. Once those are activated, you then need to find some air grease to lubricate the Yaris's hyper super duper space activated carbonated seat pulleys.
Old 05-08-2010, 05:14 PM   #7
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
There are microchips on eBay now that you can solder into the ECU. A much easier way than how we had to remove the steering column before.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 05-08-2010, 05:35 PM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Mentos in the gas tank. That's all I'm sayin'.
Old 05-08-2010, 06:32 PM   #9
127.0.0.1
yeal LOL all that got me was HUGE speeding ticket fines
I won't do that one again
How to Disable Trac Control/VSC on the Yaris TS CASTREX Yaris TS Talk 29 10-09-2014 10:17 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
