Old 05-08-2010, 05:55 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
The ultimate replaces the fuel controller and allows the tuner to control alot more things. My AFR is at about 11.5 during open loop (according to their dyno). However, my wideband is showing 10.5 during open loop. All other AFR numbers are fine during normal driving and idle.
I used 92 octance with meth injection (HEET). I didn't do a 1 to 1 ratio of meth and water. Just pure HEET. Not sure how much that raises the octane levels?
I never had any detonation problem while running the meth kit with HEET. Up until i ran the meth kit, i was using a bottle of lucas octance booster with every tank. I would only see slight detonation even without the octance booster.
I also had the tuner wire it so the compressor turns on all the time. There is now no need for the switch and the electric clutch. And let me tell you, it's a lot quieter not hearing that stupid clicking noise every 3 seconds. ;) I guess this would also allow it so I could run a fixed pulley that would give me more boost; however, I won't be the guinea pig for that.
Old 05-08-2010, 06:00 PM   #2
H3LlIoN
Drives: '09 Yarrrr hatch
More hassle than value, IMO. Housing only capable of a safe 9 to 10 psi, which is minimal gain over your current charge. You would also have to add bypass actuator, which is where expense would come in.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
iptuned.com - greddy ti-c yaris exhaust **in-stock** Invision Yaris Sponsors Classifieds Area 0 09-30-2007 06:27 PM
Greddy TiC exhaust For the Yaris Invision Yaris Sponsors Classifieds Area 17 09-07-2007 04:59 PM
