Old 05-09-2010, 12:23 AM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
The rear swaybar only "stiffens" the rear suspension when the car is cornering or when one rear wheel encounters a bump or hole that the other one doesn't. Typical straight line ride quality is unchanged. That kind of change in stiffness can only come from stiffer springs or shocks.
Old 05-09-2010, 01:48 PM   #2
Vang
Drives: 2008 Yaris Sedan
so it wont really help in preventing highway wander during crosswinds?
Vang is offline   Reply With Quote
Old 05-09-2010, 02:12 PM   #3
RedRide
RedRide's Avatar
Actually it does to one degree or another.
It should be understood that even on the highway, traveling in staight line, the suspension is constantly flexing and the end result is one side will hinder the flexing other with the sway bay installed and therefore, stiffen the suspension feel. Rarely does the road want to compress both sides of suspension equally.
Of course, one can argue just how much stiffer it will feel and also the 19mm vs the 23mm.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
