#1 | |
Also, the 1NZ-FE with a 10.5:1 C/R does have a high enough compression to use 91 or higher octane fuel, but the computer's program limits timing so that is runs on regular 87. I know a guy running a Stand Alone ECU on his N/A Echo and has increased his timing by 10° up to around 42° at the upper end of the RPMs and has gained roughly 7-8hp alone from that and premium gas. You have to remember that this engine was designed with one thought. Fuel efficiency. |
#2 | |
Drives: Bayou Blue Yaris Hatchback Join Date: May 2010
Can you get a stand alone ecu for the yaris? should be similar right? |
Drives: 07 sedan Join Date: Mar 2010
#4 | |
Learning & Upgrading
Drives: 2006 Yaris 5 Dr HB Black Join Date: Apr 2010
Anyway, just wondering waht does ECU mean? |
Engine control unit - http://en.wikipedia.org/wiki/Engine_control_unit
It basically controls everything about how the engine runs, timing, air, fuel, etc. The US yaris ECU thus far is unbreakable/unflashable. |
#6 | |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| NooB! | YarisWorx | General Yaris / Vitz Discussion | 9 | 03-17-2010 03:33 PM |
| noob question.. | msfire671 | Cosmetic Modifications (Exterior/Interior) | 9 | 02-26-2010 11:58 PM |
| Noob Section | ozmdd | Suggestions - Feedback - Questions | 13 | 10-08-2009 08:37 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
