Old 05-10-2010, 03:55 AM   #1
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
The problem is the regulator from 06 to 08. You can't take a 09 regulator and put it in and 06 to 08. It works fine for a while then goes don't hill fast from there. Caused me lots of problems ie. melted alternator wire and positive battery terminal for starters. So get and 09 + will fix that problem that you and so many people have had. The only parts you can use from than 06 to 08 alternator is the casing and the pulley. When i got mine is was 100$ but the pulley and back part of the casing was damaged. so i which over the piece and it worked find. After being tested at the shop. If your looking for one go here
http://car-part.com/ put your car, part, state, province or territory, prix and damage unit your postal or zip code if you don't want to travel to far. Your request will be there in about 10 sec. Works in canada and the us. There good for other parts also. It and online scrap / wreckers site.
Adriaan is offline   Reply With Quote
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 01:40 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
