Old 05-10-2010, 09:17 AM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
Sub/Amp Question Re: Impedence Load
Okay...quick question...
Can I drive four of these:
http://www.infinitysystems.com/car/p...=US&Region=USA
off one of these:
http://www.alpine-usa.com/US-en/prod...del=PDX-1.1000
Or will ohm load be too low and burn amp/subs?
Also, can someone post the math behind this, so I can understand it? Thanks,
- H
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 05-10-2010, 09:20 AM   #2
H3LlIoN
Oh and how much power will be making it to each sub? Thanks...
Toyota
Moving Forward
Old 05-10-2010, 09:27 AM   #3
Palmer812
Drives: 2010 Meteorite Metallic LB
That amp puts out the same power at 2 or 4 ohms(1000 watts at 14.4 volts at 1% thd). With 4 4 ohm subs you would want to run a series parallel configuration to end up at 4 ohms. That puts you at 250 watts each.
Palmer812 is offline   Reply With Quote
Old 05-10-2010, 09:30 AM   #4
H3LlIoN
Disregarding the ohm load labels, is this the proper wiring sequence of which you speak?
Thanks,
Toyota
Moving Forward
Old 05-10-2010, 11:37 AM   #5
Palmer812
Yes sir.
Old 05-10-2010, 11:56 AM   #6
H3LlIoN
Thank you Palmer!
Toyota
Moving Forward
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
konig helium question? liyux2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-08-2009 03:55 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
