Old 05-11-2010, 02:41 AM   #10
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
None of these green vehicles are zero emissions... they only move the emissions somewhere else, so from that perspective it's BS. The only advantage that I see is that you get better efficiencies on larger scales. For example, one thousand gasoline burning cars may be more polluting than one power plant producing electricity to charge the equivalent one thousand electric cars. (Note: I'm not a proponent of electric cars, just giving an example of how you could better control and regulate pollution in one place rather than one thousand.)
The typical internal combustion engine is still one of the least efficient ways to produce mechanical work in the world today. If I'm not mistaking, the best Diesel engines don't even come close to 50% efficiency and gasoline engines are worse than Diesel engines. Good electric motors on the other hand come close to 90%.
I'm still hoping that someone will discover anti-gravity or teleportation and then we'll solve the transportation problem at least
Beam me up Scotty!
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 05:36 PM
big older car vs little newer car xed General Yaris / Vitz Discussion 9 09-16-2007 05:35 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 11:58 PM
