Old 05-11-2010, 03:55 PM   #1
bst82551
bst82551's Avatar
Drives: 2008 Flint Mica Yaris Sedan
Alright, so I just tried this. First things you need to know:
* I drive an '08 Yaris Sedan with no other mods (unless you consider amsoil and wix oil filters a mod).
* I have just over 70k miles on my Yaris, over half of which are highway miles (I drive back and forth from Georgia to Texas about four times a year).
* I typically get about 30-33 mpg in the city and 38-42 on the highway.
* I drive VERY aggressively about 80% of the time (mostly while driving in the city).
After unscrewing the bottom portion of my intake, I pulled the tube off of the intake and drilled three 1" holes into the remaining piece of the bottom portion of the intake. I drove it like this for one day with a disposable STP air filter with about 8k miles on (it didn't quite look dirty enough to replace yet). I noticed a difference in the sound and what MAY have been a small boost in HP (maybe 1-2 HP), but that may have just been the "placebo effect" from the slightly deeper, louder sound of the engine.
I threw the K&N air filter on the next day and found that the Yaris became less noisy and didn't feel like it had that same boost in HP. Please keep in mind that any difference in power from this mod went, for the most part, unnoticed when the mod was completed in its entirety.
Perhaps using disposable filters will net better results for some. Either way, I'll stick with my K&N. If nothing else, I'll be saving money on buying new air filters every couple of months.
-Brian
By the way: Yes, I know this is an old thread.
bst82551 is offline   Reply With Quote
Old 05-12-2010, 09:17 AM   #2
PhillyG
Drives: 2009 Yaris
-Brian
question: in your own opinion, do you think its worth the free mod? or should i just wait and get the full intake? mine is still under warranty so i think i am either gonna just drop a k&n in the regular box or the full intake. i dont want to do anything that is not reversible for now.. although i AM gonna add cruise control
PhillyG is offline   Reply With Quote
Old 05-12-2010, 09:22 PM   #3
bst82551
bst82551's Avatar
It's worth it simply because it's free, but don't expect the kind of return you would get on a typhoon or other high-end intake. I'm happy with this setup, but I'm not looking for big power gains. Just some weekend projects, increased fuel efficiency, and maybe some extra power. I'd recommend you go for the full intake change instead of this "hack" if you're looking for power gains.
If you are worried about warranty issues, you can try throwing in the K&N filter on its own and seeing what that does (but it probably won't do much). Also.. if you wanted to, you could simply remove the tube from the bottom portion of the intake but not drill any holes. You can always snap the tube back on when it's time to visit the dealership.
-Brian
Old 05-12-2010, 10:41 PM   #4
PhillyG
Drives: 2009 Yaris
thanks bst.. i like the idea of just taking the tube off and putting a kn air filter in.. i think ill try that!
Old 09-21-2011, 03:32 AM   #5
Ravenlokk
Drives: 2008 Yaris
Intake DIY NecroBump!
I was bored, and cheap and did a custom intake today!
I wanted to avoid/minimize any permanent modifications incase i want to return the car to stock for resale or other reasons... However i did have to cut out a section of the stock foglight cover (i'll post pics of it later- but its hardly noticeable unless u kneel down and look at it from ground level).
Parts required:
~4-5' of 3"dia Flexible metal pipe ($5)
~10' of heat shield tape ($10)
4" >> 3" pipe collector ($10)
chicken wire ($10 for a huge roll) or any metal meshing to stop rocks from flying into intake snorkel
3" screw type clamp ($2)
dremel tool to cut open the fog light cover
Basicly i replaced the stock snorkel with a 3" diameter pipe that funnels air in from the front fog light. I wrapped the pipe with heat shield tape to keep as much engine heat off of it as possible. And i used the collector to make sure none of the intake charge went around the pipe from the fog light enclosure.
The job requires removing the front bumper cover, as well as the airbox to fit stuff properly etc.
Pipe after shaping / wrapping
Test fitting stuff
Test fitting stuff
Before i put the bumper cover back on, with wire mesh installed.
It was too dark to take pics of it all back together, but ill get pics up tomorrow.
Ravenlokk is offline   Reply With Quote
Old 07-23-2012, 06:52 PM   #6
fase4
Drives: Yaris TS 05
Parts required:
Test fitting stuff
Test fitting stuff
still waiting dude
fase4 is offline   Reply With Quote
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
DIY INTAKE ChinoCharles DIY / Maintenance / Service 236 04-12-2007 08:34 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
