Old 05-12-2010, 09:39 PM   #1
drew999
Drives: 2008 yaris
i had a popped tire which i put fix a flat in but then i got all 4 tires replaced with new tires and the ! is still there
drew999 is offline   Reply With Quote
Old 05-12-2010, 09:40 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
you ruined your tire pressure monitor by using fix-a-flat..... NEVER use fix-a-flat
Old 05-12-2010, 10:42 PM   #3
90tsi
90tsi's Avatar
Drives: 09 yaris
Xs 10000000
working at big O for the past 2 months and ive bet ive put in 100 cuz ppl put fix a flat in the tire.... its crazy but it eats the base of the sensor and destroys the chip inside.
my buddy at toyota told me a while ago when i tried to help a friend she had replaced one and it wouldnt read the new one, so i tried to get it to program with our tool at work. but the only way is to have the toyota read and program the serial number in.
90tsi is offline   Reply With Quote
Old 05-12-2010, 10:46 PM   #4
drew999
Drives: 2008 yaris
so the sensor is fucked
is there anyway to get the ! off the dash ?
Old 05-13-2010, 04:01 PM   #5
If you don't want to replace the sensor, you can get rid of the light by doing the TPWS bypass:
http://www.yarisworld.com/forums/sho...light=diy+tpms
Old 05-13-2010, 04:12 PM   #6
Kal-El
Kal-El's Avatar
Wonder if Fix-A-Flat (and similar products) have put a clear warning label on their cans?? Seems like a widespread problem now.
I'm glad I have an '07 which is before law required TPMS's. I know how to check my own pressure.
Old 05-13-2010, 08:53 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
wow.. surprised there's a law on that..
Shouldn't the fix-a-flat already have those warnings? if not... i smell court case! well... for a 20-50$ repair.. Hmm.. :P
Old 05-13-2010, 04:15 PM   #8
Kal-El
Kal-El's Avatar
Drive the car 500,000 miles or 20 years (whatever comes first), and hopefully the light bulb will have burnt out.
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
Yaris at Summit Point Time Trials Redbat01 Tracking, Racing, Auto-X Forum 1 05-06-2010 12:30 PM
exclamation point shown on a 2008 toyota yaris sedan dashboard SoundWave DIY / Maintenance / Service 16 06-25-2009 10:49 AM
just got back from cedar point... joey1320 Off-topic / Other Cars / Everything else Discussions 2 06-15-2007 11:01 PM
Friction Point - Clutch hal9000 DIY / Maintenance / Service 17 12-01-2006 03:55 AM
