Old 05-12-2010, 11:19 PM   #1
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
Thank you.
Did you confirm this works?
Meteorite_Marty is offline   Reply With Quote
Old 05-12-2010, 11:49 PM   #2
Originally Posted by Meteorite_Marty View Post
Thank you.
I wouldn't suggest doing this unless you change the side markers to LEDs.
With the stock incandescent bulbs you would need to use a 30 ohm, 1 watt resistor, and the resistor would get very warm when the lights are on.
Old 05-13-2010, 12:50 PM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
I didn't even realize the stock ones didn't use LEDs. Like I said, I have very little electronics experience
Focus_Sh1ft is offline   Reply With Quote
Old 05-13-2010, 09:13 PM   #4
Meteorite_Marty
Why would they get hot? Its the same bulb as the parking lights. Again, just assuming.
Old 05-13-2010, 09:25 PM   #5
The resistor acts as a dimmer so that you can distinguish between running light mode and flasher mode.
The resistors would get hot because of the current required to drive the 5W bulbs. The aftermarket LED side markers draw less than 100mW (1/50 of what the bulbs draw), so dimming them doesn't require sinking the power that dimming the bulbs requires.
Additional turn signals yarisugi Photo-Video-Media Gallery 24 02-06-2013 08:08 AM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Audible turn signals tforkner DIY / Maintenance / Service 9 08-08-2009 09:50 AM
turn signals blinking fast manborn DIY / Maintenance / Service 15 09-15-2007 01:52 AM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
