Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
I want a closer ratio gear set and shorter final drive because my drag strip can be up to 40 kms long and usually has lots of hills and corners.
Apexing Egg!!
LOL
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#3 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Can you tell us why you chose a C56 trans and not a C160 to swap into a C150? Bluevitz-rs made a good thread that explains it all that it can be done. http://www.yarisworld.com/forums/showthread.php?t=26728 The C160 transmission is a closer ratio than the C56. The purpose of this thread was in order to know if the C160 LSD fits the C150 that's all |
#4 | |||
Hmm, but on dirt. We call it a rally.
![]() But after seeing how much smaller the gears and diff are in the C150, I'd be scared at running too much power or abuse through it. |
#5 | |||
The C160 transmission is longer because of the extra 6th gear, well you could use 5 gears instead of 6? Quote:
That depends the cost of redrilling! If so it would be more worth buying an upgraded LSD |
I take it by these questions that you never had either of these transmissions apart. Sure you can use only 5 gears, but then what do you do with the rest of the input and output shafts? It won't make the transmission any shorter. All of that was covered in my conversion thread.
| C54 MANUAL TRANSAXLE service manual needed | ricepower | DIY / Maintenance / Service | 1 | 08-29-2007 07:24 AM |
