![]() Drives: 2010 yaris sedan Join Date: Apr 2010
OK, sounds good. I'll look to check for the brown and blue wires, and ECM connector and pin 40. Are these all easily visible with the air bag off, or can you direct me to any threads with info on checking these.
#2 | |
![]() For the ECM connector, you have to pop the connector, and then you can look at the business end of the connector to see if the pin is populated (shining a flashlight into the connector will help you to see if the metal pin is in the hole for pin 40). |
Thanks for your patience. Hope this is not sounding too dumb; how do I remove the lower steering column cover, and how do you tell which is pin # 40. Is it labeled?
#4 | |
http://www.yarisworld.com/forums/sho...ght=diy+cruise And, this one shows the details of checking pink 40 on the ECM connector. The pins are not labeled, but you can easily find the pin 40 position with the photo as a reference. http://www.yarisworld.com/forums/sho...e+module+%2425 |
Got it. Doesn't look to hard. With gratitude, RH
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
