Old 05-13-2010, 03:42 PM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
OEM deadening material
Taking a break!
Clean!
2 CLD Tiles.
Some of that Radiant heat insulator...
1/4" CCF and ready for MLV
With no MLV to work last night I started playing around with the amps, the 3rd amp will be here soon, maybe I'll put it under the passengers seat? or in line with these 2. I didn't realize they where so big and heavy
This one will provide power to midrange and tweeters...
PS. I will try not to forget the MLV tonight.
CLA 250, 4MATIC
Old 05-19-2010, 09:22 AM   #2
fmjhp594
Drives: 2010 Sedan
So just wondering, why did you take the OEM deadener off/out? Why not just put pieces of tile over it? I thought the more material you have to stop sound the better right...?
Thanks,
Mike
fmjhp594 is offline   Reply With Quote
Old 05-19-2010, 09:55 AM   #3
derickveliz2
Thanks,
Mike
Hi Mike,
The OEM material is very chip (bad quality), will dry very quickly and eventually "Crack"; like in a previous post (back in the trunk section) where I found OEM deadening dry and cracking, that won't be good under the area treated.
"pieces of tile over it?"
Tile aka CLD Tiles are not designed to block or stop the noise, the purpose of the CLD Tiles is to control "Resonance" on metal panels. And they have to be applied directly to metal. MLV is the material I'm using to block/stop unwanted noise, the foam also creates a small barrier but is more an absorbing material also used to prevent rattling between panels.
If I was going to use only mat(tiles) for deadening I would have to put more than 2 or 3 layers to get the same results I'm getting with MLV. It's not bad it also would help for SPL, but will increase my work load. And like I mention at the begining of this thread, I'm only spending 2 to 4 hours a week. (well some times I'm lucky and I spend more time). But applying many layers of Mat to a car is time consuming, lots of work.
I hope It helps.
D.
CLA 250, 4MATIC
