Old 05-14-2010, 08:33 AM   #1
Originally Posted by crazyandroid View Post
Ok, quick question. When installing the clutch switch, I see that the two wires go to the blue and white wires on that connection in the fuse box . . . could I just splice into those wires instead of trying to wedge some sort of connector into the same hole? I ask b/c that's what I tried and I'm not sure where my failure lies. I will take pictures in the morning of everything that I did and hopefully someone can help me. I'm really feeling like I should not have attempted this mod . . . I don't even know how to check the current to make sure that things are connected adequately.
Definitely splice - Don't wedge. The wedging can be done for a quick test, but you really want a more positive mating for the long run.
Old 05-23-2010, 10:04 PM   #2
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
What's the best way to go about splicing for the CC switch? Shave the wire coat and solder on to it?
sk8manmike is offline   Reply With Quote
Old 05-23-2010, 10:33 PM   #3
That, or use a properly sized tap splice.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
