Originally Posted by mick.wheelz
Hi All,
The other day my sub's main power wire got loose and grounded...
Causing a bunch of fuses to below taking out the P/S, Aircon, Indicators, Central Locking, ABS, speedo, etc.
I managed to fix everything except for the ABS. I have tested all the fuses and they arent blowen (although I could be wrong)
Any idea what I could try to fix it?
also, can someone take a picture of the fusebox legend under the hood, mine does not have one.
ok since the sub wire got loose i hope u fixed that ( just joking) ok lets see u said all the fuses are fine, did u check each one by taking it out and making sure, if so disconnect your battery for about 2hours this will reset your system, this should work, wait wait, did u check if you have enough brake fuild (it could just be alittle low) let me know if u come right
