Old 05-21-2010, 11:08 AM   #1
detroiter
detroiter's Avatar
One other option you can try is pulling the power steering fuse....start the car up with out it and let it run for a few minutes. Make sure the steering wheel and wheels are straight, shut the car off. Re install the power steering fuse and then turn the car back on. Don't touch the steering wheel and let the car run for a few minutes.
I had a similiar issue and that method worked for me.
Old 05-21-2010, 01:53 PM   #2
swidd
Drives: Yaris HB
Would simply disconnecting the negative battery connector work the same?
steering problem redgreen DIY / Maintenance / Service 31 09-18-2015 08:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
steering wheel problem SoundWave DIY / Maintenance / Service 6 10-31-2009 01:26 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering & Suspension Problem?! Trilixia Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 05-20-2009 10:15 AM
