Old 06-01-2010, 10:36 AM   #1
1stToyota
1stToyota's Avatar
Same here. Regular steel lug nuts always get torque-sticked. Aluminum wheels always get torque-wrenched w/ special mag sockets. Sleeved nuts get torque-wrenched.
While I'm at it, always check the balance [no extra charge] when doing rotations; takes less than 5 minutes but well worth my time to avoid the hated come-backs.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-28-2010, 08:53 PM   #2
dingbat
Drives: '10 3D Liftback
Originally Posted by TheSilkySmooth View Post
After the Toyota dealer did the 30K sevice and rotated my tires, I had to slow quick to get an exit on the expressway - now my rotors are warped bad. This is causing a lot of shaking in the steering. Should I pull the wheels?
Did the shaking start after the hard breaking? Hard breaking while turning can warp a rotor, especially if it's over/improperly torqued. Don't ask me why it happens, but I've done it myself on a couple of different vehichles.
Improper torquing can cause a warped rotor. Some older Subarus were especialy prone to this. Had a spec. of 65 ft/lbs. Barely past hand tight. Scary.
You said you have Pirellis? Check your tires very carefully for distortions in the sidewall and tread that could indicate a seperated belt. Of course, this would most likely cause symtoms all the time not just while breaking.
dingbat is offline   Reply With Quote
Old 06-01-2010, 12:44 PM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
This was NEW tires and NO rotation. Balance is OK - could be better, but Im not liking these tires on this car (pirelli P4 seasons). So far my Firestone SNOWS (winterforce) have been best by far !!?
Old 06-01-2010, 01:01 PM   #4
PhillyG
Drives: 2009 Yaris
ya gotta start small with things like these... take each tire off individually.. check for rust around the pilot bore..(if there is some.. wire brush it off) remount the tires and torque appropriately in steps.. it really could be that simple. if that is not it.. then you really might have warped rotors. got a dial indicator? if so.. check the rotors when you have the wheel off.. if not.. take it to a tire shop you trust..(i know thats not sayin much but...) usually the problem can be found with the process of elimination.
PhillyG is offline   Reply With Quote
Old 06-01-2010, 01:03 PM   #5
PhillyG
Drives: 2009 Yaris
ps.. if the problem only occurs when you brake then it is in the braking system.. if it occurs at any given time (even when not on the brakes) then it is usually in the tire/wheel combo.
Old 06-01-2010, 06:30 PM   #6
fe550
Drives: 2008 yaris sedan
PhillyG is right. the big question is ...does this shaking occur when braking only? I'm a mechanic and the 1st I do after some yahoo at the dealership or alignment shop touches my vehicals - is get home and re-torque all the lugs. Because, yes, unevenly torqued lug nuts will warp rotors after heating and cooling cycles. After working in shops for the past 15 years i wouldn't take my car to the dealership if oil changes were free!
fe550 is offline   Reply With Quote
R1 Concepts brake rotors cali yaris Micro Image 24 07-21-2009 01:02 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
New Pads and Rotors after 18K Miles??? dadi_oh DIY / Maintenance / Service 19 09-06-2007 08:52 AM
Cross Drilled Rotors for yaris Adriaan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-16-2007 03:27 PM
