DAT'S RIGHT I GOTz 2
the 90080-91229 (L)
is the same as 90919-01176 (J) as you can see they are the same (K16R-U) all depends if your car is manufactured as (L) or (J) (L)ocal or (J)apan SPEC It wont matter which you put in except the saving of the 72cents the're both DENSO brand If your VIN starts with (J) japan If it starts with a # its (L) local go figure ![]() hope this helps
| 2008 OEM S model Liftback Lip kit Part numbers | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 17 | 07-26-2010 01:33 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-01-2009 11:50 PM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
| Help Finding part numbers PLZZZZ!!! | Duckywitbigfeetz | Cosmetic Modifications (Exterior/Interior) | 0 | 07-29-2006 02:21 AM |
