Butyl sealant over silicone definitely.
You could try tossing a couple of new silica gel desiccant packs in behind the bowl (the kind that come with cameras and electronics. |
resident senior
The hole trick will work best . This is how I have modified my foglights . The hole will allow air to circulate inside the housing and cool the inside . The trick is not to puncture the reflective surface .
I'm not sure what the Sedan headlights look like , but if it were my LB I would drill holes on the TOP of the headlights in addition to the hole in the bottom. Actually I would drill some 1/16 or smaller hole(s) into the place where the hood meets the headlight . There is a lip (on headlight its clear in color ) that forms a 90 degree joint with the hood . Drill the vertical side into the headlight . You won't be able to see the hole(s) with the hood down . With holes in the top and bottom the air can circulate much better and the hole in the bottom provides a place for water to drain . Actually buying new headlights would be the easiest way .
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Take the bulb(s) out,dry the inside of the unit out and then use a product called snow seal...its for boots and outdoors stuff.It's beeswax....you apply it,use a hairdryer to make it "run" into cracks and crannies,then it solidifies/sealing the area.
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
| Headlight Restoration | Emerge | Wash, Wax, Detailing, Exterior Repairs | 23 | 06-26-2010 12:11 AM |
| Headlight fog | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 2 | 03-28-2007 06:38 AM |
